Advanced Setting Properties
Cryptomator allows configuring parts of the environment using properties. For information on using properties, see Setting Properties. All those properties can only be set in the advanced configuration file Cryptomator.cfg; they are not available on the command line. Each user can have their own advanced configuration file (“per-user advanced configuration”), which takes precedence over the advanced configuration of the system (“system-wide advanced configuration”) for that user.
Warning
Editing the advanced configuration is not officially supported.
Changes to the system-wide advanced configuration may be overwritten by updates.
A user’s per-user advanced configuration may quietly become outdated after an update.
Properties may be changed or removed without warning.
Changes to the advanced configuration may break your installation or yield unexpected behavior.
Note
A user’s per-user advanced configuration and the system-wide advanced configuration are not merged.
The per-user advanced configuration needs to contain all common properties as well as differing ones.
Changes to the system-wide advanced configuration will not have any effect if a per-user advanced configuration exists for that user.
If it exists, the usage of a user’s per-user advanced configuration can not currently be disabled. Please see this issue for more information.
For a more technical explanation of the structure and location of the advanced configuration, please see the upstream specification.
Locating the system-wide advanced configuration
Note
Editing the system-wide advanced configuration may require elevated privileges (i.e. admin or root permissions).
The following table lays out instructions to access the system-wide advanced configuration for your Operating System. The location may differ depending on Cryptomator’s installation location:
OS |
Default path |
Notes |
Windows |
C:\Program Files\Cryptomator\app\Cryptomator.cfg |
macOS |
/Applications/Cryptomator.app/Contents/app/Cryptomator.cfg |
Might be located in the “User Application Folder”: ~/Applications/… |
Linux |
/opt/cryptomator/lib/app/cryptomator.cfg |
Alternatively use the command: open $(dirname $(dirname $(readlink -f $(which cryptomator))))/lib/app/ |
Locating the per-user advanced configuration
The following table lays out instructions to access the per-user advanced configuration for your Operating System. You may need to create the file or its containing folder. If at least one per-user advanced configuration exists, it takes precedence over the system-wide advanced configuration for that user:
OS |
Path |
Notes |
Windows |
%LocalAppData%\Cryptomator\Cryptomator.cfg (*) %AppData%\Cryptomator\Cryptomator.cfg |
If both exist, the path marked with (*) takes precedence. |
macOS |
~/Library/Application Support/Cryptomator/Cryptomator.cfg |
Linux |
~/.local/cryptomator/Cryptomator.cfg (*) ~/.cryptomator/Cryptomator.cfg |
To replace a property, change the value after the equals sign in the corresponding entry in the [JavaOptions] section.
Example: To disable the tray icon change the line as follows
- java-options=-Dcryptomator.showTrayIcon=true
+ java-options=-Dcryptomator.showTrayIcon=false
To add a property, add a line in the [JavaOptions] section of the form java-options=-D[Name]=[Value] (mind the “-D”).
Example: To switch the UI language to Hungarian, add the property user.language with the value hu:
[JavaOptions]
# ... Other options ...
java-options=-Duser.language=hu
Properties
Argument Name |
Description |
OS |
java.net.useSystemProxies=[Boolean] |
Whether Cryptomator should use the system proxy settings (true) or no proxy (false) when connecting to the remote (e.g. for update checks). |
All |
https.proxyHost=[Host] |
The host of the proxy server to use for connecting to the remote (e.g. for update checks). Overrides java.net.useSystemProxies=[Boolean]. |
All |
https.proxyPort=[Port] |
The port of the proxy server to use for connecting to the remote (e.g. for update checks). Requires https.proxyHost=[Host] to be set. |
All |
http.nonProxyHosts=[NonProxyHostList] |
The hosts that are not accessed through the proxy server when connecting to the remote (e.g. for update checks). Defaults to localhost|127.*|[::1] if unset. |
All |
cryptomator.logDir=[DirPath] |
The directory where Cryptomator stores it’s log files (e.g. application log, migration log). |
All |
cryptomator.pluginDir=[DirPath] |
The directory where Cryptomator discovers plugins. |
All |
cryptomator.settingsPath=[FilePath] |
The json-file to use for application settings. |
All |
cryptomator.p12Path=[FilePath] |
The path to your device key. |
All |
cryptomator.ipcSocketPath=[FilePath] |
The path to the IPC socket used for checking for an already running application instance. |
All |
cryptomator.mountPointsDir=[DirPath] |
The directory where Cryptomator mounts vaults if no per-vault location has been set. |
All |
cryptomator.showTrayIcon=[Boolean] |
Whether Cryptomator should show an icon in the system tray (true) or not (false). |
All |
cryptomator.integrationsWin.autoStartShellLinkName=[String] |
The name of the link created for starting Cryptomator at system startup. |
Win |
cryptomator.integrationsWin.keychainPaths=[FilePathList] |
The paths to load keychains from. |
Win |
cryptomator.integrationsMac.keychainServiceName=[String] |
The name of the keychain service. |
Mac |
cryptomator.integrationsLinux.trayIconsDir=[DirPath] |
The directory where Cryptomator looks for icons to use for the system tray. |
Linux |
cryptomator.loopbackAlias=[String] |
The name of the WebDAV loopback alias. |
Win |
user.language=[Language] |
The language to use for the application interface. |
All |
user.region=[Region] |
The optional region/dialect to use for the application interface. Requires user.language=[Language] to be set. |
All |
Property Argument Types
Cryptomator’s properties come with the following types:
Argument Type |
Valid values |
Example |
Notes |
Boolean |
“true”, “false” |
cryptomator.showTrayIcon=true |
Boolean values are not quoted. |
Host |
Unquoted hostname or address |
https.proxyHost=example.cryptomator.org |
See paragraph “https.proxyHost” here. |
Port |
Unquoted port |
https.proxyPort=4242 |
See paragraph “https.proxyPort” here. |
NonProxyHost |
Unquoted hostname or address with optional wildcard (“*”) |
http.nonProxyHosts=*.example.cryptomator.org |
See paragraph “http.nonProxyHosts” here. |
NonProxyHostList |
List of NonProxyHosts divided by “|” |
http.nonProxyHosts=localhost|127.0.0.1|*.example.cryptomator.org|[::1] |
String |
Quoted text |
cryptomator.loopbackAlias=”Cryptomator” |
Accepted characters/values are not defined by this document. |
DirPath |
Quoted full path to a folder in the style of your OS, but always using “/” as separator |
cryptomator.logDir=”/Users/Admin/Logs” |
Might use substitutions. |
FilePath |
Quoted full path to a file in the style of your OS, but always using “/” as separator |
cryptomator.settingsPath=”C:/settings.json” |
FilePathList |
List of FilePaths divided by “:” (Linux, macOS) or “;” (Windows). |
cryptomator.integrationsWin.keychainPaths=”C:\file.one;C:\file.two” |
The entire list is quoted instead of individual entries. Might use substitutions. |
Language |
Unquoted ISO 639 alpha-2 or alpha-3 language code |
user.language=de |
See paragraph “language” here. |
Region |
Unquoted ISO 3166 alpha-2 country code |
user.region=CH |
See paragraph “country (region)” here. |
Substitutions
Substitutions are used to dynamically resolve the content of some properties depending on the environment Cryptomator is started in, e.g. by inserting the path to the user’s home folder. They may only be used in properties that start with cryptomator. (mind the dot) like cryptomator.logDir. All occurrences of the following substitution keys – in supported properties – are replaced by their respective variable values:
Substitution key |
Variable value |
@{appdir} |
The application installation directory. |
@{appdata} |
%APPDATA% (Windows only). |
@{localappdata} |
%LOCALAPPDATA% (Windows only). |
@{userhome} |
The user’s home directory. |
Unknown substitution keys remain unchanged; a key without a value is replaced with an empty string.
