Vault Recovery
This section contains instructions for recovering Cryptomator Hub vaults using the vault recovery key.
Cryptomator Hub vaults can be recovered in two different ways:
Online Recovery - Reestablishes Hub controlled access management for a vault in case the vault admin password got lost
Offline Recovery - Restores vault data access of a hub managed vault in case of a disaster (e.g. Cryptomator Hub is down and immediate data access is needed)
Online Recovery
This recovery method should be used, if the vault admin password got lost. In the process, a new Hub vault with the same key material as the “to-be-recovered” vault is created. The membership information of the old vault cannot be migrated, hence all users/groups need to be added manually afterwards.
Requirements:
Access to Cryptomator Hub
Write access to the storage location of the vault
Access to the recovery key of the vault
In Cryptomator Hub navigate to the vault list, click Add and Recover Existing
Enter the recovery key for the vault you want to restore. If you enter a recovery key from a different vault, the recovery will not work.
Proceed with Restore Vault.
Enter a new vault name, description and vault admin password. The new vault admin password is required to grant or revoke access to the vault.
If successful, a new vault has been created. Proceed as follows:
Click on
Download zipped vault folderof the new created vaultUnzip the downloaded folder
Copy the file
vault.cryptomatorof the unzipped folderBrowse locally on the device, directly in the cloud or network storage to the location of the vault folder. In that folder, replace the existing
vault.cryptomatorfile with the one you just copied.
Afterwards, you can manage vault data access over the newly created vault in Hub. You will need to regrant permission to the vault members, and then the vault can be unlocked by the team.
Offline Recovery
This recovery method should only be used in an emergency, i.e. immediate data access is needed but Cryptomator Hub not reachable. In the process, the authentication needed to unlock the vault is changed from Hub- to password-based by creating/changing vault configuration files. If these changes are synchronized to the online storage, everyone with the chosen password can unlock and access the vault data without requiring a connection to Cryptomator Hub. If you don’t want that, ensure that the vault is stored at an offline location without any kind of synchronization.
Note
This process is reversible. See the end of this section.
Requirements:
Access to the Cryptomator desktop application
Open the Cryptomator desktop app, right-click on the vault you want to restore in the vault list, click Show vault options in the opened context menu.
In the opening window, select the Recovery, read the label description and click the Convert to Password-Based Vault button.
Enter the recovery key for the vault you want to restore. If you enter a recovery key from a different vault, the recovery will not work. Proceed with Next.
In the next step choose a good password used for unlocking the vault. Cryptomator requires at least 8 characters but we recommend you to use a longer phrases such as pass-sentences. The bar below the password field estimates the strength of your password.
If the conversion was successful, a success message is shown. You can close the dialog box. This vault is now converted to a password-based vault.
After the conversion, when unlocking the vault, you are prompted for a password and only the one chosen in the previous step leads to a successful unlock.
You can reverse the offline conversion. In order to do that, remove the following files:
all files named or starting with
masterkey.cryptomatorvault.cryptomatorthe most recent
vault.cryptomator.XXXXXXXX.bkup
Then restore the original config by renaming vault.cryptomator.XXXXXXXX.bkup to vault.cryptomator.
You can then unlock the vault again using the Cryptomator Hub.
